Using existing image as basis for map?
Yes, still a slight rookie when it comes to this.
I've seen how you can hide/display various sheets in cc3. It is possible to use a sheet as an "import image" sheet and use the image as a basis for the map?
I'm trying to correlate a satellite image, a game map, and convert them into a cc3 overland style.
I then trace over it, using the other layers and sheets. Then delete the item on the bmp layter when I no longer need it.
Thank you :)
If I didn't I would then have to read screams of maps no longer loading.
