Catalog settings changing during edit?
Hello all.
Just purchased and downloaded the CC3 and Annual 2.
I've run into a strange bit of behavior - as i'm adding to the map, my catalog buttons start to act strange. I was putting down some forests in the "pete Fenlon" style, and wanted to swap to putting down some structures. When i pressed on the structures button (second row, 6 from left) the sybols that showed up on the left were not the fenlon style, but some strange filled strctures.
How do I make the buttons select the right symbols again?
    edited December 2009
    Check File -> Drawing properties, to make sure the drawing style is set to "Pete Fenlon"
    Then, in the command line, type:
    SYMICONFLOAD<SPACE>FENLON<ENTER>
    (Note that there will be no visual indication or confirmation that the command executed successfully. Also note that this command should normally be executed automatically by CC3 each time you open the saved map)
