Using Real World Data
                    Good day all. I'm quite certain that I'm havig an issue with uploading real world data. I'll downloaded it from the site (still awaiting my boxed version) and saved it to my desktop. When I try to load the real world data as a new binary map, it asks me if I would like to use the info file that is found with it. Does anyone have an exact procedure that should used when downloading, saving, and loading real world data?
Thanks In Advance,
Squandered Youth
                            Thanks In Advance,
Squandered Youth
1. Download ETOPO2.dos.bin
2. File/New
3. Select Binary
4. Select the downloaded ETOPO2.dos.bin file
5. Specify the correct parameters...
Per-Sample Info: 2 byte, LSB First (Intel), Signed
Line Width: 21600 bytes
Header Length: 0 bytes
Wrap Horizontally: On (I think)
File Data: X Start 0 samples, Width 10800 samples, Y Start 0 samples, Height 5400 samples
Map Edges: Top 90, Left -180, Right 180, Bottom -90
Missing Data: no data -9999, Replaced checked, New Value 0
6. Click OK
7. Click Next
If you wish to experiment with these parameters, the FT help file describes them.
Directions for downloading another (NOT ProFantasy supplied) dataset from the web and using that is available here:
http://www.welshpiper.com/node/74
Edit: hmm.. Seems like Tim posted while I was writing my reply.
Note that by using the PF supplied ETOPO5 dataset, you should be able to use the header file supplied without entering parameters yourself, but ETOPO2 is better though, although also quite a bit bigger.
http://www.ngdc.noaa.gov/mgg/global/global.html
which was posted this past July. I have not tried to use it yet though.
I downloaded EPOP02 Bin file and renamed it "Rename ETOPO2.dos.bin to ETOPO2.bin" it was never called "ETOPO2.dos.bin" Just "ETOP02.dos" when I downloaded it.
I downloaded the ETOPO2.hdr file provided and its in the same folder
It has all the altitudes just no Water Levels just like the info on the FT disk.
Changing land size or water size does nothing to the map.
pvernon Which file do you need to download for the ETOP01?
What did I do wrong?
Can some one just post a FT file of Earth who can figure this out. I'm pretty upset right now. Took forever to download this file and I still can't get it to work.
Seems like your browser tries to display the file instead of downloading it, which is not really a good idea. Right click on the link and select the download option instead.
BTW....ETOPO 1 is in beta-testing right now. (It's supposed to be even better)
