PDF documentation
My CC3+ is not in the C drive as there is not enough room for windows and EVERYTHING else on my computer. So I have it in my E drive. However I can not find any documentation pdf's on my system. I have no idea where they are being stored. Specifically looking for Symbol Set 2 and how to use it properly.
My CC3+ Menu does not show SS1 & 2 for some reason despite me owning everything ProFantasy offers. Any idea where to find out where the software decided to stick the documentation?
    Documentation pdf's are stored in the Documentation subfolder of your CC3+ data directory, whereever you have placed it.
    The lack of buttons for SS1&2 is normal. Those buttons triggers the appropriate menus for the various add-ons, but SS1/2 don't have their own menus, they just use the overland and dungeon menus respectively.
    There aren't much documentation for SS1/2 though, since they are basically just new styles and symbols that otherwise behave the same way as the standard overland/dungeon stuff. Once you start a new SS1/2 map from the new map wizard, you have access to all the relevant symbols and tools belonging to those styles in the same way as a standard overland/dungeon map.
    edited February 2023
    I just installed the CA2022_Setup (which finally worked thankfully) to get the documentation menu for last year. Now I usually download and install each issue as it becomes available so I didn't need most of the files in the Annual setup but while the "Tools -> Add Ons -> Annual Volume 16" option was added before there was no menu page behind it until I ran the setup. There should be a slimline setup for those of us who install CA issues monthly and only need to add the documentation menu.
