13th Age Map
JulianDracos
Mapmaker
So I thought this was going to be an easy/quick map. But then I needed to draw a gorge and there was no symbols/terrain for it, so I have to do it myself. Then I needed to make another piece of land obviously higher, so I used a bezel. Later on, I was like, I can just use the contours. Those looked nice, but seemed off with the other land raised it. I should have just removed the bezel, but instead I raised the land for everything that needed to be.
And then I kept modifying from there . . .
Unless there is some issue or suggestions on how to improve, it, I think I am done after I add text.
