A few creating questions
I'm new and playing with CD3.
I have a few questions.
Is there a crop tool in CC3/CD3 and I'm missing it?
After you have moved it into PS (I use PSP) what kinds of effects and things do you do to your maps? I assume labelling but anything else?
and.....
The tutorial did not cover how to get the different colored housing, like the map on the front of the site. Blues, yellows, reds....
  • One of the houses symbols are vari-color. Look in the upper right of the symbols.
    I loaded Cities->Filled->Fantasy.fsc as an example.
    There is a red building, and a building that is the same color as the color selector. Look for a small square in the upper right of each square of that symbol. Change the color in the color selector, click okay, then the color of the building should change.
    But, in the other set of buildings in the Fantasy.fsc set, are buildings of different colors.
    This is the set that has Fantasy a 1, Fantasy v 1, Fan Frill a 1, Fantasy DFrill v 1, Smoke a 1, and Smoke v 1. To see all of the smybols in each one, click on the + on the upper left.
    + [color]
    building
    name
    I don't remember if that set is part of CD3 or not.
