Is this the "Select Coloring Scheme" page from the "Lighting and Color" property sheet (right-click + Lighting and color or Map>>Lighting and Color)? If so, it should look like more or less like this in FT3+:
If there are no lighting files listed here, the "..." button lets you pick the directory that FT uses to get its lgt (lighting definition) files from.
If that's not it, can you post a screen shot of the "terrain color panel" window? I'm not familiar with that term in the context of FT.
this is the panel that has no listings.should i do a total reload .have a fractcal terrain 3 disc and a fractal terrain pro disc also.cannot find find the files for that directory in the download i did from profanasty.
It does look like there might be something not quite right with your current installation, so a reload is probably in order. The FT3 program download from ProFantasy should have the normal set of lgt files in the installer.
reload success. have all the terrain colors listed and operational.thanks much.am a map interest person.this will be my video game. I CAME,I WONDERED AND I MAPPED IT.
Are you talking about FT3+ and the optional Beta test update?
do not know of any beta test update.the terrain color panel has no color listings of any kind for selection and use.
thanks for your response. will do a reload.
maps from your mind are the dangerous kind.it is there that they must be......
