Random Street Resets to Default
I am using the city builder tools to create a gothic style city. i am trying to use the random street tool to fill in the holes along roads but i noticed there wasn't a gothic option so i tried to make one. I created a new option using house settings set everything to CD3 A Gothic changes some colors and other options hit "OK" and tried to lay down the buildings using the tools. The tool places buildings that were not remotely close to what i had selected. i figured i messed something up so i went back in and messed with the house settings again saved everything and tried to use the tool again. still the houses placed did not match my settings. i checked and it looks like the template is resetting to the defaults for CDC3C Wooden and Fantasy which i think is the settings i had selected when i went in and modified the settings for the gothic option i created. can someone please let me know what i'm doing wrong?
Make sure you pick the new setting from the dropdown box before you start.
I have to go out now, but will check back later. Other's might be more help.
Did you make sure you saved your street settings?
This is a screenshot of the Street Options window. As you can see, I created a "Street settings" entry named "SS5C Greengulf":
Like Loopysue mentioned, you might still need to select it every time you open your map.
