Can't TAB through some Symbols - Creepy Crypt
Some of the symbols in the Creepy Crypt annual that should be random won't change after placement or when TABing through them. Some examples are the Sarcophagus, Slab Flat, & Gravestones. It changes once or twice and that's it.
Anyone else have this problem?
Under symbol set options, check the ones you don't have checked.
On my cellphone but it is something like use random symbols.
Not sure what you mean by this Jim. I also have the same problem.
Back on my computer.
Under options there is a []Disable random transformations
make sure that isn't checked. I've done the same thing using other symbol sets.
Thanks for the idea JimP but that isn't it. Some of the collections simply aren't working properly. Some of them are fine.
Thanks for confirming that it's the same for you Quenten. I'm sure once everyone gets back from their travels it will get fixed. 🙂
The collection you mentions seem fine for me, but I just gave them a quick test.
Have you perhaps expanded the collection in the symbol catalog window? If you expand the collection (+-sign), and then pick a symbol from the expanded view, CC3+ takes this as a sign that you want full manual control over the process. and stops doing random picks.
No that's not it either Remy.
I'm going to try running the latest update and do a repair install if the annual. It's just odd that some work fine and others don't. I'll try to track down the issue if I can.
Discovered that the problem only exists in the sample map that opens when first installing the annual (Greymoor Cemetary). Not all of the symbols in the symbol manager are set to be one of a collection so of course they can't be tabbed through.
They are fine when starting a new map. I guess I should have dug a little deeper before posting here. Sorry for any confusion. 😊
No problem.
Oh dear! I'm sorry it has caused such confusion.
The example map was created before the symbol catalogues, so the symbol definitions aren't quite right.
