Changing the Screen size on the screen sheet ?
I have extended the map border, but of course, I also need to change the hollow rectangle on the Screen sheet/layer to the new size.
When I do a list, it says line width zero. Start parameter zero, end parameter 10.00.
How do I do this ?
Thanks !
Easiest way to fix the screen is to first run the COLLARDEL command to remove the old screen, then COLLARAUTO to generate a new one.
Fantastic !
Thanks !
edit: Took me a second... I forgot to read the command line. All fixed !
On to the mapping.
