Doubled copies
I'm guessing that I inadvertently toggled an option that I can't find to untoggle.
Whenever I copy an entity, it makes two copies of the entity some distance apart.
How do I reset to normal?
After you place the copy, are you *right* clicking the mouse to end the command? A second left click will place another copy (not end the command), and if you go immediately to clicking another command (which also cancels out most commands), you might not realize you've done that (placed a second copy).
Also, check these settings: Go to Tools -> Options to get the Options dialog box. Under Selection Options, make sure "Select with right button context menu" is checked, and "Enable left button pre-selection" is NOT checked.
Hope this is helpful.
I'm definitely only clicking once, but getting two copies of the single entity.
My options are checked and unchecked, respectively, as you suggest.
Ciao, Ralf
