Using different bitmap fills for different base maps
Is your choice of Bitmap fill styles limited by the type of overland map you start off with?
For instance, if I click in the FS / fill style box near top right of interface and go to the Bitmap Fill Style tab, I get a very different dropdown list depending on whether I started with a regular Overland CC3 template or a circular Mercator map. Is there a way to use the fills from Overland CC3 on the Mercator map?
You can import them. See this FAQ entry for details:
Thanks Monsen. I think I saw this information previously, but it didn't quite register. Now that I've seen it in context (of wanting to use fill styles that didn't seem accessible), it makes a lot more sense.
