Splitting landmass with fractal line
Is there a way to split either a landmass or a fractal poly with a fractal line, that way you could have complementary pieces remaining on each side of the line that would fit back together?
You could use the same drawtool you used to create it - not to edit it (because that would lose half the landmass), but to redraw the thing as two parts using the trace option (press T while using the drawing tool and trace the coast part you want to keep for that half of the landmass).
Thanks - between using the regular landmass tool (with and without Edit) and the Trace functionality, I should be able to draw and refine to get what I need.
