What should Spectrum Scrub Terrain settings be?
There is a typo in the scrub terrain for spectrum. It tries to use the CA163 Scrub.symfill but there is no file name for that. There is a CA163 Shrub.symfill so I changed the macro for that.
How the background for this is like solid 10. It is not using any type of color background. I am assuming that is wrong. If it is wrong, then what should I set the background terrain style to?
Solid 10 is a semi-transparent bitmap fill, which should already exist in the style template (if it doesn't, just shout and I will explain how to get it there). It's intended as a shadow.
That's interesting about the typo. Thanks for letting us now. I will notify Tech Support so that it can be put right for future users.
OK, I thought there might be some yellow or brown background.
Also, there is no image displayed with the terrain for this. Even though I corrected the macro, the image is still blank. Hopefully that is fixed as well.
No, just a shadow.
If you mean the drawing tools don't all display unless you go to Advanced and look at the list, we know about that one. It's on the bug list.
