Fractal Terrains 3 world generation
Alison Stevenson
Newcomer
Is it possible to set global temperature, global rain levels etc at world generation? Or maybe to change them (globally) afterwards?
You can't set it at generation, but you can set them via the global operations afterwards. (Tools -> Global Set)
Thanks <3
In the long ago times of Fractal Terrains and Fractal Terrains Pro (and 3), it took some command line parameters that let you specify the world information. Some of them might even still work.
It was a way to get a little bit of integration of FT with other programs. Note that these are command-line parameters passed to the program at startup, not something you can enter while the program is running.
