Text on a curve workaround tip
The Text on a Curve command only writes clockwise on an arc, because an arc is drawn as part of a circle with only some shown. (You can add an arc and then move one of the nodes to demonstrate this.) If you right-click Explode and choose Line To Path, then you'll be left with a curved path of the same shape (or close enough) and you can put text along it. You can then flip it if you want your writing to go the other way.
This is useful for writing in titles, and the ribbons under crests, where you want to be sure your arc has bilateral symmetry.
