How do I unlock Aspect Ratio on HighSpace Maps?
JulianDracos
Mapmaker
I was trying to make a map in Cosmographer using the HighSpace maps. I am wanting a specific ratio. However, the size seems locked in. If I change one number, the other number changes. If after starting the map, I change the drawing size, then it also changes both values. I suspect this has to do with the aspect ratio of the backgrounds. The issue is I am not wanting to use any of those backgrounds.
What is bothering me is that I do not want to use the backgrounds. I think I can make the map using the Traveler sector map. But I am still annoyed that I cannot get around the system not permitting me to change the aspect ratio. Is there anyway I can work around this?
You can edit the Resize map note, it is responsible for controlling this behavior.
Templates are generally locked if they use borders or other graphical elements that cannot be freely resized and still look normal.
Where do I find the resize map note?
