CC2 Pro Graphic Artifacts
I do not know what I did but just today, but Smooth Path and Smooth Poly objects are now showing their guide lines. I have included a PDF that shows the problem. If you look at the brown hill terrain and the river you will see white lines. These are the paths that defined the objects. I am using CC2 Pro with CD2 Pro, DD2 Pro, Cos2 Pro, SS (1, 2, 3) Pro, and SM Castles.
Does anybody know how to undo what I have done?
Edit: I did run several of the macros in the Fcw32.mac file to see what they did. O.o
Edit2: This is only on this one map. I created a new map and did not see the guide lines.
Thank you.
Thank you.
Thank you.
