Lines on Gaia map view output from FT3+
I'm loving the new FT3+ but found what might be a bug.
When I save an elevation map as a PNG it saves fine. But when I try to save a Gaia map I get these streaky lines. This example is 9000 width so I thought it might be the size, but I've saved smaller images and it's the same.
Any thoughts? I'm using the latest FT3+ in Windows 10. I had no problems with this on the earlier version.
