How to change floortype
Hello!
I was making my first house from inside with the symbols of schley, and I dont know how to change the floor type from stone to example, wooden, or anything else.
Here's simply the floor which I want to change:
Hello!
Hi Nikode :)
If you hide all the sheets except for the FLOORS sheet you should be able to use Change Properties
 to change the fill style of the floors.
Thanks! 👍️
Then how can I change the main backgrounds style, I'd like it green but I would like to have some stone around the house.
You can change the main background the same way, it is just a polygon like the floor.
If you just want a small radius around the house, just draw a new polygon (Box
 or Polygon
) on top of it with your desired fill. Since you may want separate effects for it, I recommend creating a new sheet for it that is just after the background sheet in the sheet order, and put it there.
