Export effect difference
Hi All,
just finishing off my first large overworld map, went to export and found that the effect scale seems to change between what I am seeing in CC3+ and the final export.
Is there a setting I'm missing somewhere to get these to match what I'm seeing?
A part of the exported image:
The same section in CC3+
Thanks
Looks like your effect is set up to "Percent of View Width" instead of map units or percent of drawing extents width. Go in and edit the effect in question, and change this section. Do note that you may need to tweak the size of the effect after doing this, as you basically change the baseline for the sizing.
