Worldbuilder's Compendium and the rest of tutorials won't open?
Hello. I too bought the bundle and installed the Worldbuilder Compendium. When I open it, CC3+ tells me to click on the images, but nothing happens. What can I do? I really need to start learning there.
Thank you
I don't have the actual setup for that myself, so I don't know exactly where the links are supposed to lead, but you should find all the pdf's inside your CC3+ data directory (The directory you chose during installation, default is c:\ProgramData\ProFantasy\CC3plus). Most of the guides are sourced from annual material, so they'll probably reside inside the Annual subfolder, while I guess the compendium itself is probably in the Documentation subfolder.
Note that since you say "start learning", if you're not familiar with CC3+ at all, the best place to start is with the manual, which also contain many tutorials. You can access this from the help menu.
Looked at it, but there are no pdfs. Just sample maps...
To show a bit more detail for what Remy has already said, the actual pdfs are within each of the individual folders within the Annuals folder here:
C:\ProgramData\Profantasy\CC3Plus\Annual
The shot below shows the pdfs available in the One Day Worldbuilder - Issue 155
I have all the annuals, so there are probably going to be many more issues in my shot than you have in yours (unless you also have the whole set)
Hi @FeatherInk ,
I also found that a link didn't open at first for something in the bundle but then lost track and couldn't remember which link had failed.
Anyway, the PDF should be located at:
C:\ProgramData\Profantasy\CC3Plus\TutorialsHope this helps in the meantime.
