The best way to check for a correct SS1 install is to start a new map:
- New Map > Map type: Overland Maps (decide settings myself) > Map style: Ss1 Fantasy A - after saving the map, clicking the catalog buttons should load the symbols in the Fantasy A style, and the drawing tools should bring uo the corresponding tools.
You should get a menu with several SS1 styles.
If that doesn't work, use the button I have marked with red in below screenshot. You can then open symbols manually.
The symbols are located in this directory:
[wherever you installed]ProFantasy\CC3\Symbols\Maps\SS1
Hope that helps,
Ralf
