CC3+ crashes when trying to "change like draw tool"
![zsos](https://secure.gravatar.com/avatar/c87a899218151c2d992158f5bbd0debe/?default=https%3A%2F%2Fvanillicon.com%2F7643f81c73c5e1802485ad49ff3101a4_200.png&rating=g&size=200)
Hello all, I am took landmass from a Fractal Terrains export, placed it into a new file to get it in a particular style (following this video: https://youtu.be/ZuhB_LXr3Sg ). Whenever I try to change the largest landmass to the default style it crashes. No problems changing smaller landmasses. I've updated to 25, and still have the same problem.
It's my first time posting on the forums, so I'm not sure what else to include that would be beneficial to those helping.
Thanks.
Best Answer
Loopysue ProFantasy 🖼️ 39 images Cartographer
It may be that you have too many nodes in the large landmass. This can be a problem with FT3 exports, since FT3 is capable of exporting many more nodes than CC3 can manage. Try reducing the number of nodes in that large landmass before you convert it by typing the command SIMPLIFY, hitting enter, and then adjusting the minimum distance between nodes in the command line to suit. If you get it too big you can undo and try again.
Answers
That did it! Many thanks!
You're welcome :)
