Duplication of Sheets and Layers
Does anyone know if it's possible to duplicate the contents of a sheet / layer without risking moving the original or the duplicate? I'm working on an overlay no matter hard I try I can't get it to perfectly line up with the drawing under it.
-Avotas
-Avotas
There are several ways and I am sure that some of the more well-versed guys will explain potentially better than I, but try this -
There is a Copy To Sheet command (and - quoting the help): You can also 'copy', select your entities, and when the dialog asks for a clipboard origin hit ENTER (for the default 0,0), paste, and then type 0,0 to paste the copied entities into the same location.
To duplicate the content of a layer you use the LAYERCPY command and select by layer (right click or L).
In both case, all entities will stay at the same coordinates.
To duplicate a single entity you can copy it from 0,0 to 0,0 (enter the coordinates in the command line, don't use the mouse) and then use the prior selection to change it's properties, including the layer or even the sheet with Edit Entity (MPEDIT).
