How do I alter a coastline?
I've drawn a landmass, and need to cut off a small piece where it looks weird. I don't see a tool for this? Also, this will be integral with my second map, which is an 'after cataclysm' map. It will be best done by just making a copy of the original, and moving the coastlines or however that's done.
Any ideas?
Any ideas?
Rather than using the landmass tool to draw a island/continent over a Sea background, start your map with a land background and draw your oceans/sea over the top. This way when you need to "cut off" a small piece you can easily just draw more ocean to cover up the land you need to "erase."
Hope that helps!
His solution works very well and is incredibly easy, just pay attention to the command prompt at the bottom of the screen while you're reworking your fractal. The secret is the RIGHT CLICK before selecting the end node. I've always seen the edit option but never worked it through.
