CC3+ keeps crashing
![Mr_Foo](https://secure.gravatar.com/avatar/9e5e403be04ef47ff2682b1a07105539/?default=https%3A%2F%2Fvanillicon.com%2Fcd69b5c814f89bace0abb5fd960e6637_200.png&rating=g&size=200)
I just installed CC3+ on a new PC (Windows 10 Home 64 bit) and it crashes every time I select Open or when I select new and go through the options and select finish. Any ideas on how to trouble shoot this? Thanks!
Here is a brief troubleshooting checklist:
If you have done everything this way and you are still having trouble you might have a corrupted installer, which can happen sometimes over slow connections. So it might be worth re-downloading the installers and running them again in repair mode.
Those are all the things I can think that might have gone wrong, so if you are still in trouble it would be time to contact Tech Support through your account page.
Also try opening a different map by clicking on that map's fcw file, not Open in C3+. There might be some corruption in the map that is currently in CC3+. The software loads the last map edited.
