Cave Editing has Stopped Working
When I draw a cave, it puts down floors and walls. I can then go back, press E, and edit the shape. However, this has stopped working. I believe the issue has to do with sheets. I created new caves and placed the floors on a new sheet and the walls on another new sheet. Now when I go to edit, it only edits the floor. It does not alter the walls. In fact, even if I turn the floors off, I did not seem to be able to select the walls and edit them even if that sheet is the only one available.
So how can I get the edit function to work correctly again? I really do not want to have to put everything back on original sheets, edit, and then move each part back separately. That is why I created the new drawing tool to begin with.
Best Answer
Answers
