City Builder Labels - Colors
1) Is there an easy way to label a finished map in the cities expansion for CC3? Just seeing what options there are.
2) When I perform a style sheet for contours, it changes the colors of some of the contours, but not others. I want it to leave the color alone and just apply the effect. Any ideas?
For example, in two of my jungle areas with a contour they turned white to match the mountains contours. However, I had a forest and another jungle that did not change their color once the style sheet was applied.
2) Did you check if the unaffected entities where on the right sheet? What do you name a style sheet? Is it a sheet effect or a drawing tool?
It is a sheet effect, but maybe the contours are on the same sheet? I will look and see.
Thank you for the fast response!
