CC3 Spectrum Overland "Symbols in area" function
![arshesney](https://secure.gravatar.com/avatar/b438900f538bd9f90d225184d41fa0dd/?default=https%3A%2F%2Fvanillicon.com%2F5571e33e36aa0767c3d3d6b9d54af20d_200.png&rating=g&size=200)
Hello,
I have an issue with the "Symbols in area" function when using the Spectrum Overland theme: only some type of trees are placed in the designated area: Woods Cacti, Gum trees, Wood Joshua, Woods Jungle and Woods Snow pine, the remaining ones only paint the area. Something is happening, because a noticeable redraw happens whether the symbols are placed or not
Using the tool from the terrains list (image below) or the command from the Draw menu makes no difference.
Checking advanced tool configuration there are macros attached to all of them and the .symfill files are present in data\system\fillers directory.
This map has a sample of every tool, thank you for any help you can provide. Pleas let me know if any other information is needed.
Seems to be an error with the .symfill files themselves. I've alerted the appropriate individuals.
If you extract these symfill files in your /System/Fillers/ folder overwriting the existing ones, does that solve the issue?
Yes! With the files from this archive every single tool works as expected.
