Quick Moving a group picks up an entity on a frozen layer
Hi all,
I have a question regarding Quick Move picking up an entity on a frozen layer ....
I am creating a simple/quick battlemap floorplan using boxes for rooms and lines for corridors (essentially a dungeon schematic). A player's position is tracked by moving a colored disk. The disk is a group entity (solid circle, hollow outline, a bit of text). The disk uses a layer named PCs.
I draw a line for a corridor and use a different layer (e.g. WALLS or FLOOR). I freeze this layer.
With a player disk positioned on the line, I try to Quick Move the disk. If I click on a disk edge inside the line, I usually move the line, not the disk. See attached example.
I've confirmed the line on the frozen layer cannot be edited but I thought that would also mean that the line could not be moved.
Should a line on a frozen layer be movable?
Is there a better way to ensure the line is not movable?
Thanks
No I don't think so.
But what you describe is more like a VTT than cc3plus.
I think Remy would probably be the font of all wisdom on this, Crazyant, but I also think he will be resting right now, so we might need to give him a bit of time to recover from setting up this new forum last night ;)
I am pretty sure this is a bug. I'm reporting it to the relevant authorities.
Thanks for the response and followup Monsen.
I figured out a solution that will work for me in the short-term. In case another low-time user has similar need, here it is ....
The player disks can now be moved around, over the image, without problems.
