Separating Two Entities
I am working on a map in which I want to use parts of the landmass from each of several different FT generated worlds. Here's what I've done so far.
1. Generate world in FT.
2. Save as CC3+ File (Coastline Only)
3. Erase everything except the landmass.
4. Explode the landmass.
5. Erase everything except the parts that I want.
6. Rinse and repeat for another part of my combined world.
Here's where I'm getting into "trouble." As I get into editing the land from one of the new coastline maps, I realize that each line segment I select actually selects two lines. As far as I can tell, each of the two line segments exists on the same sheet and on the same layer. Is there a way to delete just one of each set of two lines?
I've attached one of the maps for reference.
