Did sort of feel like I should have made more stores, and at least one Inn, but that would likely have gone over 100 maps for this set. So I told my self, sternly, no.
Yea, the world maps is a link error on my part. What happens is that the atlas defaults to the world map if an invalid map is provided. This makes a lot of sense for visitors to the site, but makes less sense in thumbnails like this. I'll fix the error.
Do you want just the changed fcw files, or a modified zip file ?
edit:
Here are the fcw files. Parchment background.
Thanks Jim.
I am working on your maps now, but it takes some time getting all those maps into the atlas.
No problem. If you take less than a week, I'll be pleasantly surprised.
I seem to be missing the description for dungeon_city_entrance01.FCW.
It has lots of numbered areas, so I assume it has one?
Correct. I thought I had put it in there. Here it is.
Well, that's one huge batch of maps added to the atlas. Thanks for the contribution @JimP
I'll make fewer next time.
And thank you Sue.
You can always go back and make more buildings later. The point isn't necessarily to complete an area each time.
I am a bit burned out on d&d type maps and I have started on a revision of my starship.
I can fully understand that. Take a break, it will do you good.
And going slowly on the starship. I was trying to play Everquest earlier today, and the one server I wanted to use... is having big problems.
Maybe I just need to setup my new tent and sleep outdoors one night.
This is excellent work Jim. A massive project.
Thanks Mike. Note I didn't do the world maps.
It was rather tireing to.
Thanks. I thought I was seeing things.. I am still tired today, but its the weather I think.
