CA155 WorldBuilding
Hi. I'm giving FT3 another crack after several fails. I'm following the CA155 Supplementary sculpting tutorial with the exact settings listed.
My first question - Are the Offset brushes really supposed to be 500 x 500 H & W? That pretty much covers the entire map. Curious.
Also, I never got a "white" starting altitude/map which I see was the bottom colour on the altitude scale. At -30000 altitude my map was blue.
Thx.
Cavan
Thx.
Cavan
If you have set the Editing resolution higher than default in the World Settings and clicked the Apply button before closing it, those brushes should only be about the size of the UK on a world map at most.
They're meant to be fairly big so that you don't gouge huge and narrow trenches or raise razor ridges anywhere on the map, but not as big as the map itself.
I didn't even know it could!
EDIT: It will appear to snap if the editing resolution is low as it jolts from one set of height points to the next. When the resolution is 8000 it should look pretty smooth. Make sure that you clicked the Apply button after setting the editing resolution before you close the window.
CC
It's why the tutorial is written the way it is.
cc
