Crashing on Save As...
Lately I have been crashing whenever I try to Save As.. any type of vector (raster? I get them confused) format (.bmp, .jpg, .gif, .png). I have trimmed the maps to get them fairly small and shut down other programs running, thinking maybe it was a memory issue (I have 4gig RAM) but that doesn't seem to help. This seems like a recent problem as I was able to save even my largest maps as recently as last month.
Here is the information I get:
Problem signature:
Problem Event Name: APPCRASH
Application Name: fcw32.exe
Application Version: 0.0.0.612
Application Timestamp: 476086d3
Fault Module Name: Effects.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 48e52dab
Exception Code: c0000005
Exception Offset: 0000fb61
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional Information 1: 6dc2
Additional Information 2: 2daab9c918383610cdb7b5c97f38d0cf
Additional Information 3: 6d74
Additional Information 4: 42e205c4d11203b8815be7ada6b538bb
Thanks for any help on this!
Problem signature:
Locale ID: 1033
Like discussion
Method #1:
Download Snag-It (30 free trail)
File->Print
Print to your Snag-It Printer
Hit Properties
Hit Advanced (bottom right side)
Select your paper size, and then select 600x600 dots per inch under Print Quality.
Set all your normal settings
Wait (it takes a second, the Snag It will open)
Save as your favorite format.
Open Photoshop or Paint.net (Free) then crop/resize as needed.
Print
This method produces a 32x43 inch document (if set to 8.5x11 paper stock) at 150 DPI.
Method #2:
Save
Restart CCS
Save your map before doing anything else. Sometimes that will work
*edit: Just saw the post with the PDF editor. Same process, different programs.
-Avotas
Oddly, the SAVEAS worked too. O.o
What is the menu cmd for saveas rectangular BMP?
alt i) WBS
For both commands, follow whatever the status bar or popup dialogs tells you to do.
I've been able to save the map as a png 800x600 but as you can see from the attachments, the resolution is very pixellated. I've also included a print screen to show you what the map should look like. (For those that might recognize the layout, it's from a Shadowrun 4 adventure).
