How to use drawing tool from another template
I am using Spectrum Overland template to make historical Levant and try to make out Jerusalem by drawing a border, I try to use the border drawing tools from Modern Fantasy template, but it just didn't work.
I try to draw it myself, so I made a new sheet and copied the same sheet effects from Modern Fantasy, but it just didn't work.
May I know how to draw the same border style? Thank you very much in advance.
To use that border style correctly, you need to draw a solid filled polygon that covers the entire area. (Line width: 0, fill style: solid). The effect should then fade it appropriately like you see in the sample. You may need to tweak the width of the edge fade effect to fit your map size.
To use that border style correctly, you need to draw a solid filled polygon that covers the entire area. (Line width: 0, fill style: solid). The effect should then fade it appropriately like you see in the sample. You may need to tweak the width of the edge fade effect to fit your map size.</blockquote>
Thank you, it worked!
