Unable to open temporary BMP file
I've successfully exported my first map to a PNG file, but I tried to export a new map today and I always get this error message. I've tried saving in a different folder, running CC3 as admin, nothing works, and I haven't changed any settings since exporting my first map. Any ideas what's wrong?
If anti-aliasing is on, try to turn it off and see if you can export then. If it is already off, try to reduce the image dimensions.
The max size you can export is heavily influenced by the complexity of the current map, as well as your available memory. Sometimes, CC3+ won't be able to reserve enough memory, which can cause the export to fail. Rebooting the computer may help in that scenario.
I don't see any problems. Maybe Ralf or Quenten will see something I don't.
