Wall Thickness, Inside of Wall line up With Floor
Is it possible to have the inside of the wall edge line up with the floor edge instead of the centre of the wall? Then when you make a 20'x20' room with a 5' thick wall you don't loose 2.5" all around the room.
I don't think there is an equivalent in DD3.
I have recently started doing dungeon maps myself (I'm usually an overland and city mapper), and I have discovered the easiest way to remedy this by picking (or editing) a snap grid that has snap intervals that are half the wall thickness and then drawing the rooms half a wall width beyond the desired size of the room, like this.
