Issue 12 "Annual 2007" not complete in theory!
Okay, I got an issue with the Annual "Creating your own Style", So what if I wish to create a drawing tool, that use a bitmap from the CSUAC. I looked into it and it does give you the option to use other bitmaps, than the ones in the list. Why is this and how do you go about adding or correcting this. That issue does not cover enough I think.
Open the fill style dialog and select bitmap fill. Click new, enter a name, then click find to locate the bmp.
Adjust settings and you're done. Your new fill style is ready to be used in the usual manner or in a drawing tool. 2. Is the new style also the current fill style ?
Some tools do not have a specific fill style but use (and show) the current one (the one displayed one the FS right upper box of the CC3 window).
I just tried all I told you and noticed a lot of tools displayed the new filling style. That's because after 1. the newly defined bitmap fill style was set to currently selected fill style (an option in the fill style dialog, though...)
Hope it helps.
And Joachim is right, many drawing tools use the "curent fill style" as their fill. These will change their look depending on the currently selected fill. Otherwise tools only change when they are saved.
