Crash When Using Command Line to Path
I am trying to trace the real map of the Meditteranean countries, firstly I use parabolic curve to trace Line 1 and convert it to path using command Line to Path, it was done perfectly; and then I trace the rest (Line 2\3\4\5) and try to convert it to path again by using Line to Path, but this time it crashes; at first I thought maybe the line is too long and too many nodes, so I split it into Line 2\3\4\5 and convert it again, it still crashes and keep crashing.
Is there something I've done wrong or is there a solution?
The purpose of I am using these commands is:
1) I use Parabolic Curve to trace the coastline, it is better than fractal or the default cubit curve;
2) Use command Line to Path to convert the newly drawn line into path so that I can combine them together using command Combine Paths;
3) After I successfully trace all the coastline, convert them into path and combine them together, it will automatically change to default land, or I can use change like draw tool to do that.
