Swamp terrain
I wish to create a terrain style a little similar to the Terrain, Default Forest, but instead of placing symbols on a backgroud I want to place the swamp hatch style on the background.
I think I need the Use Macro command function, but I don't know what to type in the command box.
Who can help me out?
I tried some things already, but I end up with some errors ChkData DAV has no pending DRQ, but I don't know what that means.
I used the COPYSHT, CHANGEFS and CHANGEL commands, but I need something more for the macro to run properly I guess.
    You shouldn't need to use a macro when you wish to use a hatch style
    Create a new drawing tool using some shape. Use the properties button to set background properties.
    Then hit the outline button, set the outline to be an extra entity, and hit the properties button in this dialog. Now, uncheck the "use current properties throughout" checkbox, tell it to use a hatch style, and select the desired one.
