Changing Size of Individual Symbols in an Auto-Forest
Corradus
Newcomer
Hello All:
One of the features I adore in Cc3+ is the ability to make a whole forest by drawing out a closed poly. Absolutely brilliant time-saver. Just one question.
Is it possible to change the size of the trees within that poly? If so, how?
Hi Corradus :)
You need to change the Default Symbol Scale in the Drawing Presets dialog
to something greater.
This will allow you to draw a new patch of forest, but will not update existing ones.
Don't forget to change it back to the initial value after you are done (in this case 1).
Loopysue to the rescue again! Thank you so much!
You're welcome :)
