Lettering and labels of the clickable functions is unreadable due to size - any fixes?
Hello all, sorry to bring another newbie question. (And one that MAY technically be unrelated to CC3, at that.)
I am using CC3 on an HDTV. My PC displays to the TV at 3840 x 2160. The text of the function buttons is rendered in a way that it runs off the edge of the buttons and disappears.
I looked at my display settings (Windows 10) and found that all the text on most apps and programs are displayed at 300% size, so it's visible from my couch. However, it appears to have encountered a problem specifically with the CC3+ app.
Does anybody know how to fix this?
    Bottom right of CC3+, click on the hammer. Select the size of the icons you want. Click on okay.
    Enixine
  • I tried JimP's method, and even though I restarted CC3, it didn't have any effect on the text visibility in the tiles. (I'm not 100% sure it changed the tile sizes either, though I have not measured the pixels.)
    However, I found a possible workaround. Above the left-hand columns of tiles, there is an "Options" button. Clicking on that takes you to a menu which allows you to specify the widths of the function tiles. I set this to 300 instead of 100, and now the text is visible, as illustrated below.
    Not exactly the most elegant of solutions, but at least it works!
    I went from medium to large. Worked for me. So I don't know why it didn't for you.
    Might I recommend you increase the height too, this will make the symbols a bit bigger in the preview (they try to display as large as possible given the space they are given.)
