CC3 land tool Issue
I still have some master files for my old maps before the update 8. It seems as if the older land (default) drawing tool is more a high quality bitmap versus the new one. The new default looks like it's from SS1-B. I highly dislike that as the default. I much rather prefer the older default. Here is a picture I made to show what I am talking about. Is there away to get Picture B to be Picture A for the new default?
    This seems to be only a matter of size and scaling. Open up the Fill Styles dialog (and the bitmap fills tab), and choose the fill "land dark green". Depending on what you need, you can check or uncheck the "Scaled" box and set the "Width" and "Height" settings to different values.
    If you want to change this for all maps based of that style, open the matching template file in your CC3 folder and do the changes there.
    Hope that helps! Ralf
