Lines Arcs Paths and Multipolies
Hi all,
Searched the forums, but could not find a definite answer.
I have a several lines and arcs I want to connect to create a path. When doing that the arcs become straight lines. Changing them to multipolies keeps them as real curves, but creates "leaks" as the arcs and line do not connect exactly.
To be sure I tried in 2 creation orders - creating the arc after the lines are in place, and drawing the arc and then attaching line on its end. The arcs where created using the "start,end, bulge" mechanism. The arcs/lines were drawn using the "Endpoint" modifier so in theory the lines should all connect.
The "Smooth path" used elsewhere in the drawing, connected correctly to the lines.
So....
1) What is the best practice here?
2) Is there a way to control the number of straight lines an arc turns into when it is changed into a path?
Thanks,
Avi
PS. is there a search command that to give only answers that contain ALL keywords, but not next to each other? (e.g. + in Google so +Arc +Path)
