Random Questions and Problems
Calibre
🖼️ 39 images Mapmaker
Hey all,
Happy New Year!
While proceeding to make various maps for my weekly game and following Ralf's videos, I'm noticing differences and permutations. List:
Overview: I'm doing a small area outside and Inn and I am going to do a floor plan for the Inn, itself. I chose Ryecroft Town Style as I do not yet have SS5:
1: Clicking 'DEFAULT' button does NOT bring up Ryecroft symbols, but looks like crude, what?, vector symbols? I have to click the symbol folder, backout of CD3 and then select Ryecroft in the list then double click that to load the defaults back in. Why?
2: When I go to FLOORPLAN the options available do not list SS4 even though I have SS4 AND Ralf's video shows it should be available. He even says it should be available. Why?
3: the F9 key to 'ON' the roads as he did in his Ryecroft video does not attach in a esthetic manner. The second road I 'ON' shows a separate entity which I cannot find a way to combine. LIST shows both roads as a line, 2 diff. widths and then a fill. I have shunted the second road to its own sheet to mask this jarring visual error yet, I can still see divisions. I'll double check the TOME to ensure I'm not using the wrong procedure---but I'll point out that Ralf in fact used this technique in his own Ryecroft Video. Why?
4: I chose the exact same options Ralf did in his video and when I click on the hotspot, instead of a floorplan, I get the roof drawn on it---though Ralf chose this exact option, his video showed the actual floor itself---not the ROOF over it. Why, please?
5: Every floor shows the ROOF though I deselected Roof Drawing. I chose DD3 floorplan from the list since SS4 is not showing. I do have this product. I'm seriously confused by this.
Please, please explain
thanks
Cal
Hi Calibre :)
Would you mind sharing the file?
Heyyas, Sue
1: the 'Default Catalog' button on the bar with the catalog buttons in CD3. When Ralf clicks this on his video, it loaded the 'default' catalog. For me, it loads these cartoonish symbols---probably from an old catalog.
2: SS4 is installed. But it does not show as an option for me to use as it did for Ralf when he was doing his floorplan in his video---even though I own it.
3: I have a 10' muddy road to which I F9'ed a 5' muddy road from the side. There is no merging of these roads. You can clearly see the 5' road on top of the 10' one. I temp stuck the 5' one on a new sheet just to keep going till I got an answer ?
4: Every floor listed showed only the roof even when I choose multiple levels in the drawing wizard. Is this something lacking in Ryecroft style, I wonder? Or yet another blunder on my part ?
5: as above. Yeah sure, let' me load it up ?
PS: I notice a red line above the roofs which informs me: file to load...*scratches head*
thanks
Cal
When I click any of the catalogue buttons I'm getting SS3a catalogues. I'm not entirely sure that I really understand how those buttons work myself, and have to admit that I rarely use them. I tend more to hit the folder button at the top of the catalogue panel and go find the right FSC file. Because I've been doing it that way for 4 years now, I know where everything is to find it quickly. I also know this is not the correct way to do it, but it works.
Did you try reinstalling SS4?
If you use TRACED on the roads to trace their outlines as a single entity, then adjust the sheet effects like this, you should hopefully end up with something like you want. That Inner Glow effect wasn't helping! Glow is better. I've switched it off here to show just the reduced EFI.
I don't have your floorplan maps, so I can't really help you with that one. Maybe Ralf or Remy can throw more light on it when they see the thread?
Thanks! I'll definitely use TRACE on them then. I used the inner glow because my OCD ? If I see black outlines on objects, I want to see them on ALL things in the map heh. Just the inker in me I guess. Remember? I asked about your cliffs with a similar question heh.
PS: well, guess I coulda used 'outline in black' CAD tool doh.
anyway
thanks
Cal
You're welcome, Calibre.
Maybe someone will be along later to answer the rest of the questions you have.
Hey, Sue
You said you traced the roads, what tool did you use?
thanks
Cal
AHHH. You meant the command. Thanks, that worked. Lack of Sleep = Lack of Reading Comprehension
Its TRACED, by the way. A newer and better version of the tool.
Before you use it make sure you have the correct sheet, layer and fill style selected as active. It's not a disaster if you didn't do that because you can use Change Properties to put things right again. It just makes things easier and faster.
Regarding roads: I put each "class" of road on a different sheet:
Interstate/Autobahn
Heavy Duty multi-lane
Medium duty
Light duty
Unimproved/gravel
Trail/dirt
Path
Track
Each is a different color and sometimes width. Not all are used on every map.
Railroads are placed above interstates.
Thanks Remy and mike.
I usually draw roads by my own methods. I was just following along Ralf's vid and noticed things didn't quite match up heh. I'll do them correctly from now on ?
Sue, thanks for reminding about that command. It's quite handy, now.
Cal
Trying the Repair with SS4 I am getting this error:
Could not access network location $ARTDIR$.
hmmm. Better send this off to tech support.
Cal
Did you download a fresh installer like Remy suggested? Sometimes old installers don't work all that well.
Yes, it was a new one.
Try to uninstall SS4 (using the standard add/remove programs in windows, as this will call upon the old installer cache) and reinstall using the new installer. Hopefully that will fix things. (Remember to reinstall the latest update when you are done)
Thanks, Remy
I've followed instructions and I can use SS4 and the Forlorn Cottage, etc. I just can't get it to list as available when I try to use the 'floorplan' button in CD3 like Ralf did.
thanks for the assist
Cal
That doesn't sound like it's working properly, Calibre. Remy has covered all the usual things, so it's probably time to contact Tech Support about it.
