How to make a wall meet a circular tower in Perspectives 3?
Hello,
I want to have my tower as a part of a wall go seamlessly with the rest of the city wall. The second picture shows an example from a top-down view. However, this is very difficult to accomplish in an isometric form (first picture of my attempt). Any advice?
Best Answer
Monsen Administrator 🖼️ 81 images Cartographer
The wall is made up from a set of grouped entities. You can unlock groups and delete the segments you want to remove. But this is a bit tricky because you will be dealing with the individual components that make up a perspectives entity, and that can get a bit confusing, since drawing things in perspective is basically just tricking the eye.
Answers
Since you would generally want that wall to be in front of the circle here, you should put it on it's own sheet, one which is drawn on top of the circular wall.
Okay, how do I make a hole in the circular wall though? As per the second image.
Alright, thank you.
