How do I get my new maps onto Roll 20?
New to ProFantasy, have been using DPS before hand. I have made a new map but can not figure how to convert/ rasterize it to work with roll 20, any help welcome?
Answers
File -> Save as, then pick an image type such as .jpg. You'll probably want to hit the options button in the dialog AFTER picking the file type to set up the resolution you need.
Ralf did a Live Mapping session on this just last week here:
If your map has the standard square grid where 1 square = 5 feet it's very simple. Divide the dimensions of your map by 5. So a 200ft x 160ft dungeon/battle map would would 40" x 32". Hit saves as, select jpg bitmap. Go to the options tab on the dialogue box. Type in your dimensions and set the resolution to 70px per inch. Make sure the pixel size is correctly adjusted, for my example it should be 2800 x 2240. Check the box that says Constrain image to...(I'm at work and can't recall the exact wording). Leave the check box about restricting to the map border unchecked. Click OK. Hit save and you're done.
