Sheet Effect Texturize behaves strangely?!
When I add the effect Texturize to a sheet I get one version in the preview on my screen (while changing parameters in the dialog box) and a different one in the final output on screen when leaving the dialogbox).
It seems to me that I get what I see when the option Global sun is unchecked. But using exactly the same values for the Sun Azimuth and Sun Elevation in the dialog box gives me an other shading than the preview I get when I use the Global Sun...so you get different results for the same options?!.
Can somebody confirm this?
Here is an example I posted earlier: The first on is a screen dump of my preview while in the Texturize dialog box and the second one shows the result after leaving it...?
