Wall Shadow, Directional not showing
Hi All,
I am pretty new and still working through tutorials but I am having a problem. I am using a normal village map and putting on some rocks, roads and thatched buildings. The rocks have shadows and work, the roads are blurred just fine but the buildings are supposed to have a glow and a "Wall Shadow, Directional" but it does not seem to show when I turn on the sheet effects.
Am I making a newbie error?
Many thanks, Kevin.
    Hmm.... what template did you start with? If you re-select the matching effect setting in the Sheets & Effects dialog (e.g. "CD3 Bitmap A") , does that fix the issue?
    If not, you could post your tutorial map here, so we can take a look at it.
